Looking at putting this MaxTrac K882445 - Shop RealTruck.com 4.5 spindle kit on my 2014 Ram Expess 2WD. Considering my options on tires.. Anyone have this set up with 33s? ( aren't factory 20s and tires almost 33inches) or would 35s be good to go.
Man 20inch 35s ain't cheap!
hey there I would just like to let you guys know that factory wheels will work without a spacer and our 4.5" spindles clear a 35" tire no problem. There is actually a gentleman on here that posted pictures of his truck running just our 4.5" spindles up front, our 3" rear kit on factory 20" wheels with some 325-60-20 tires and he said everything cleared just fine, no rubbing, no spacers and no trimming. If you go with aftermarket wheels as long as you stick with a 9" wide wheel then the +1 or even the -12 will work. Just depends on how far out you want your tires to sit. Our spindles will work with up to 5.5" backspacing. If it were me i would run the +1 offset which is a 5" backspacing. Not too far out and not too sucked in. Plus better clearance on 35's but both will work you may just have to trim more with the -12mm. Hope this info helps! Thank you for the support!
Thx I have these chrome clad 20s on my Laramie. Mine is red/silver with chrome and the black wheels everyone does looks silly and the chromes Ive seen I'm just not impressed with for the price. Still need more than an anonymous picture or two to spend the money.
Oh Sean I wasnt expecting you to DO anything about it but thanks... Sorry if it came across like that! I was just expecting to keep looking for more confirmation as it happens. I understand with all the vehicles/ versions etc its tough to find someone with the same exact setup. A thread with 2wd trucks with your spindles would be awesome to compare all the tire options for stocks and others but theres not many of us. I dont even think you guys have instructions listed for 2wd yet...
My situation is that my truck sits 2" lower in the front so first I just wanted to level it but I dont want to use coil spacers. This lead me to spindles which was nice because I would like to upsize my tires but no definitive info on tire sizes makes me pause.
Then some local CST dealers all say I cant use my stocks with their 4" lifts and I'm not really into buying new wheels. There are no decent maxxtrac dealers in my area so here I sit.
