wakeboardcraze
I purchased an AMS racing mds delete for my 14 Ram (ams cam, lifters and diablo tuner) installed the kit and re-assembled everything. I installed the diablo tuner with MDS delete option and started the truck. it barely started but did run, ran like trash and stalled. tried again and wouldn't start. if i keep rpm above 1500 it will run but sounds like timing is out, threw one code p0300 for random misfire. checked compression of all 8 cylinders and have about 180psi -200psi. timing marks were installed with cam phaser at 12o clock and 2 marks on chain with mark on gear centered, and crank gear at 6o clock and 1 mark on chain with 1 mark on gear. Is there anything i may have missed anyone can think of??
POSTED BELOW IS THE DIAGRAM I USED FOR TIMING
View media item 30420
