mods in mind
Earls5.9
5.9 Magnum
Got headers,exhaust, CAI on the list. Would like a mild cam and a tuner! And gonna lower it not too low though. What is a good cam and what else do I need with the cam? And will 3rd gen 20" rims fit my truck? 1995 rcsb 1500 2wd 5.9l
E
Earls5.9
5.9 Magnum
So there is nothing I can do to the PCM if I am gonna do the cam headers and exhaust and CAI?? I don't want to invest and not be able to manage the power. Can I just cut the cats off and what about the o2 sensors?
BeauDuke01
and you'll need spacers to run 3rd gen wheels.
E
Earls5.9
5.9 Magnum
What is a good cam? Company lift duration so forth
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Lots use Comp cams. If you can find one for the FI Magnums Summit also makes cams now too....actually I think they're made BY Comp FOR Summit. lol
Merc225hp
NA
truck
gas
Stay .480 or under as thats the max the stock valve-springs can handle, stay in the 112 -114 range. I am more partial to Cranes Cams as they made them for Mopar performance for our motors.
E
Earls5.9
5.9 Magnum
Thanks guys been a lot of help. I am looking into the M1 intake too. What to do all at the same time since it will be tore down. Just had neck surgery so getting the wish list together lol. My 95 5.9L has the egr right? Which intake do I need and if I get a bigger tb which one and what bout the injectors and rails?
Merc225hp
NA
truck
gas
Not to sure what you had done to your neck, but I have C5-C7 fuzed. I hope you are doing well!
It should have the EGR yes. So M1 with EGR part number is P5007398AB and install kit part number P5007638.
As for injector's good chance you will have to up size but not by much, I went with Accel injectors and they have not let me down yet. For your year truck 39psi is what the fuel psi runs at. The stock fuel rails will work just fine but if you are looking for bling and plan on upgrading the fuel system at some point then look at these, Dodge Dakota 5 2 5 9 Fuel Rails Sold as A Pair RMR 056 Assy | eBay
A wide-band 02 gauge should be on your list as well.
E
Earls5.9
5.9 Magnum
C4 -C6 fused. Appreciate it brother. I have it on the list but what all do it do/monitor? And does it have a o2 like plug on it? Just want to get the right one
Merc225hp
NA
truck
gas
Best healing bud!
Look for a kit, it will come with everything you need shy of an 02 **** that needs to be welded into the y pipe in front of the cat if you have one. Autometer and FAST are two to look into. Don't **** with narrow band.
E
Earls5.9
5.9 Magnum
Well I just changed plugs and one broke off in the head so it looks like its off to the pull a part for used ones!! This sucks.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
make sure the used heads are cleaned and checked REAL well for cracks between the valve seats.
Stupid-ass thin castings....:nono:
Goodie1990
