- Nov 2, 2020
- 10,300
- 13,226
- Location
- El Cajon Calif. 92021
- 2016
- 3.0 ecodiesel
Some people have had a good experience with gently prying up on those springs around the battery
I bought a replacement key fob from eBay and used Alfa to program it and then swapped my factory cut key into the new fob. Worked fine since then.I was having similar issues, as dumb as it sounds try taking your key fob apart all the way, gently squeeze the battery tight to the circuit board and press your remote start button and see what happens. I had help and this is actually what my issue was. I found some thin foam (maybe 1/8") that I cut a piece out from and placed it behind the battery.
Both of my fobs were doing the same and it fixed both. Door handle sensors now work like they should along with the remote start
I originally had this post in Electronics and never received a response, si figured I'd try it here! So I've got a 2014 Ram 1500 4x4 Hemi ,I've been having issues with my key fob! Over the last winter I lost the remote start capability. It would work every once in a while, but it took 3 or 4 attempts for it to work. Replaced the battery in the fob , but problem remained. Now I get in the truck and it shows" no key fob detected "! I replaced the key fob battery again and it helped for a day or two, but then again "no key fob detected". If I hold the fob right next to the start button ,it will start! It's obviously not the key fob because I've changed batteries and switched fobs. Any ideas what else it could be?
Thanks!
Hmmmm. Kind of sounds exactly like what my '16 is doing.... But bulletin specifically says '14In prodemand. I found a Service Campaign Bulletin: P15 Reprogram radio frequency module
I cant copy and paste but it says that eventually they can cause slow or no passive entry response, no response to RKE commands or display dashes for tire pressure readings in cluster. Im going to give my deal a call and ask about this.
