Mud flaps
steelhead1981
2016 1500 big horn crew cab.
Purchased some weather tech mud flaps and it should be easy right... the top screw on the drivers side will not come out so I can install them. Is it possible it's stripped from the factory? Every other one comes off no problem...
Thanks
Sent from my SM-G900V using Tapatalk
huntergreen
of course its possible, check with WT.
blrmkrl83
Iowa
Try to get a putty knife under the head of the screw and apply some pressure while turning it. Probably put some tape down first so you don't scratch anything.
S
steelhead1981
Still won't come out... I'm going to call the dealer on Monday if I can't get it out. I've only had this truck 3 weeks. I'm worried if I do get it out it won't go back in.
