JSMITH8505
- Feb 26, 2019
- 64
- 58
- Location
- BIRMINGHAM, AL
- 2018
- 6.7 CUMMINS
I chose to post this here because a lot of you tow large RV trailers and I wanted to give you my experience.
I do hotshot hauling with my 3500 DRW 3500. My weights are fairly moderate, as Truck, Trailer, and load, I'm rarely over 22,000 lbs, which is comparable to those who tow 5th Wheel campers, hence why I chose to post this here. My wheels are factory original and came with the truck.
I do a daily precheck as required by DOT. I wont say I look at the rims daiily, but in a week, I'll check them 2-3 times out of a 6 day work week. Tire pressure is accurate with the dash readout, so I go with that.
2 days ago I just came through Arizona and the desert of S.E SoCal. It was 115 degrees most of the day. I watched my tire pressure monitor all day and saw that it maxed out at 91 psi. (fronts, which I run at 80 psi).
My speeds were low 65 AZ/ 55 California. I debated on bleeding some air out of the fronts but decided against it.
Yesterday I noticed that the right front wheel (17" Factory Alcoa's) had a crack in it, about 3 inches long that wasn't there the day before. Heat? Pressure? Rough roads beating them up because of higher pressure?
Hmm. ok. So I changed it out with the spare and went on my way.
I don't recall running up a curb, or doing anything that would damage it, but stuff happens,and after 150k miles who knows..
Today I saw that the left front had started a hairline crack. It wasn't there the day before, but now it was. It looked decent, and I only saw it because I was REALLY checking, (hands and knees checking). I thought I'd keep an eye on it until I got to my destination where I could buy 2 rims and remount the tires.
So I started today's drive and made it 30 miles when the rim split, (cool temps mid-80's) taking the tire with it. Luckily I was in 8 o'clock traffic and moving 30 ish mph. I ended up putting the "Bad" tire from the day before on, and limped into town.
2 days- 2 Alcoa Rims with large splits in them.
I cant imagine what would have happened pulling a long gooseneck trailer at highway speed if the rim burst.
I've made the decision to switch to steel rims and ordered 2 spare tire rims at the dealership, and in the meantime I'm sitting in a parking lot watching the Vacaville forest fires burning in the distance waiting until the wheels come tomorrow.
So- if you tow ANYTHING, check your rim condition. Or consider switching your steer tires to steel ones.
I also found that after market aluminum wheels have even lower weight limits than the factory ones. So don't think they're all the same if you tow.
Steel may look ugly, but it beats having your trailer land on top of you from a burst wheel and end up in the ditch.
If you've never had a rim let go, let me tell you it's about 5x more pull than when a tire blows. If you're on a long, downhill righthand sweeping curve at highway speed, and the left rim lets go, it's gonna hurt.
Be safe out there.
Be safe out there.
