My Ram
jknappen
Kentucky
Finally got around to posting pics up
R.L.K.
Bristol , Tn.
Nice looking ride !
I read you have Bils on order , you'll realy like them , better than stock imo .
Looks like 2.1" would level you out , I went 2.8" but I had a bit more rake than you after seeing your photo .
Not sure what your asking about on your other thread though , upper strut mount ?
jknappen
jknappen
Kentucky
Front view
jknappen
jknappen
Kentucky
Nice looking ride !
Upper strut mount. Sits on top of the spring and strut. Its what holds the spring on the strut and mounts the strut to the body
R.L.K.
Bristol , Tn.
Gotcha thanks ! , did you ever find a P/N ?
Why would you want to Change them out ? When I installed my bilsteins , it's been a while but I don't remember that would Benifit you in any way ... unless of course something is wrong with yours .
jknappen
jknappen
Kentucky
Just figure while they were off might as well replace them. They are relatively cheap 30-35 bux or so
R.L.K.
Bristol , Tn.
Hmm , I know several have damaged them due to installing the washer for the bilsteins improperly under the nut instead of under the " upper spring mount " on the piston of the shock .
You should post up the P/N HERE , may help someone in the future ... did you go with the OEM ones ?
jknappen
jknappen
Kentucky
I will get a part number as soon as i find one.
