marlinfshr
- Jun 7, 2016
- 3
- 0
- 2007
- 4.7
07 4.7 1500 4x4 to be exact.
I am in the process (3rd day tomorrow) of installing a Zone 3" body lift on my half ton Ram. Problem after problem after problem, then a possible big one. My steering, though disconnected would not compress any to put in the extension. The PA instructions (I know, mine is a zone but the instructions are terrible on the zone kit) stated that sometimes it doesn't disconnect until lifting.
Well, here I am with it now lifted and it still didn't disconnect. Tapped it and it came apart. The possible problem is that the shaft now just flops around, it didn't compress any and is still as long as it was, so there is no way for the extension to fit.
Am I royally screwed now? Doesn't the steering shaft need to compress (or not pull out, so there would be room to slip in the extension. It looks like an easy job but it seems impossible. Am I going to need to call a tow truck after I get the front end back together?
Please, I need some advise ASAP as my truck is sitting in pieces in the driveway and I need it for work. I gave myself two days but it looks like it'll be a solid 4 when/if done.
Thanks!
Thanks!
