Need help with Sun Machine
rod7515
Im hoping to find someone that has infomation or may have used a Sun Interrrogator 1805 tester. I found one in an old garage service station and ended up bringing it home. It uses 3.5 floppy disc to run. I looks as though each year in the 80's had its own disc. There are GM dics 80-88, chrysler 81-87 and ford 81-90. It also has other discs however I did not find one that was a generic that would allow me to use it on anything so I could set timing, check exhaust for carb adjusting and use the scope to see each firing cylinder. I basically bought this for my dad who used a sun machine but his was an analog machine and this one is computer operated. Let me know what you know! Thanks Rod
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
Rod, I found this site--Vintage Sun Automotive Test Equipment. I didn't review the article.
Jay
R
rod7515
Thanks Jay. I'll give it a read over once.
Rod
