Mike77
I have a 2015 Ram 1500 Crew Cab with the 6 speaker non alpine sound system. I have recently swapped out the dash and door speakers and I have decided that I want to add a 4 channel amp to power the 4 door speakers and run the dash speakers off the factory head unit for better balance (I tried adding 4 ohm 10w resistors to the 3.5" kickers I recently installed and they are still too bright for my liking, and I am not getting enough volume out of the new 6x9's). I have several questions before I start ordering product.
1 -I am looking at using an audiocontrol lc2i line output converter. Which speakers are best to tap off of, the front or rear channels? I plan on running a 4 channel amp off the lc2i to power the door speakers and also a mono amp to power some subs.
2 -I plan to run a pioneer gm-d1004 amp to the 4 door speakers. Using a combination of the lc2i and this amp will I run into issues with the radio not sending signal due to a lack of resistance?
Thank you for the help!
