Newly leveled truck, new shocks, & ran into problem.
MoparSickness77
So yesterday I installed the rancho quiklifts, they are a complete coil over. The truck was making a popping like sound and it was from the worn front shocks.
The driver side went pretty easy, just removed the upper and lower ball joint studs from the knuckle, tie rod end, sway bar link, and then the knuckle itself. That made removing the strut easy.
When I went to the passenger side I ran into the common problem of the stuck lower shock bolt. It was stuck good and I was about to cut it until I came up with a way that worked. Now the truck sits level (just need rear shocks now) and the ride is much better. Here are some pictures from my phone, I'll probably post some more later.
ImageUploadedByTapatalk1344612718.885985.jpgImageUploadedByTapatalk1344612735.659503.jpg
MoparSickness77
MoparSickness77
I wanted to give it a try since I needed new shocks and wanted a level and to replace my coil springs. So far so good and the shocks are also adjustable for different ride qualities.
Birdman-68
New Baden IL
Congrats. Want to share how you got the stuck bolt off? Others might like to use the same method.
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
The truck looks great. I have heard great things about these, so I added them to the site last week. Its good to get some real world feedback on these. Are you planning to run the Rancho 9000's out back to match the fronts now?
MoparSickness77
MoparSickness77
Thanks I like them and can't wait to see how they handle on some real bumpy roads. I think I will look into the 9000s for the rear. Well see
MoparSickness77
MoparSickness77
My impact only did so much so I just used my 1/2 ratchet and a 4lb hammer to get it out, and 1 1/2 cans of PB blaster. I soaked the bolt ends that were sticking out and worked it back into the sleeve then twisted it around and let the blaster work inside. I did that for awhile and hitting the bolt with the hammer while I was twisting it. After awhile it came out and cleaned the sleeve out with my 12ga. Shot gun brush and used my wire wheel on the bolt.
bigbadram1500
Springfield, IL
Sweet. I've heard of those but didn't know much about them. Interested in how they do, I may eventually have to do something like that and get rid of my leveling kit.
(popped this over to lifted sec)
ramhunter9
P-Star Jeep Wrangler
Sold a set of these to a member a few months back ... he PM'd me today he is having issues with the driver side sounding funny ?
Most likely they were not installed correctly I dunno . Waiting on his response .
Coasty993
VA
HEMI 5.7
Good morning Senomar...is that how you got the lower strut bolt out? I have tried everything and it would not budge. I even put the impact on it like you did with no luck. Did you turn it with the wrench while hitting with the hammer? I am trying to install a Trailmaster Coil Spring Spacer style lift. I have it all apart but cannot get that lower bolt out.
MeMyselfAndMyRam
St. Paul MN
Yea that was me. Still haven't had time to bring her in for a look over. Been crazy busy with archery opener around the corner. Im curious what it is, il be sure to let you know.
I have them set at there softest setting now and its nice for everyday stuff. Had a little fun tonight on the way home from work and they felt great!
Coasty- Trying to get those bolts out myself cost me a lot of money:Grenade: Mine where locked solid and I ended up destroying the bushing. Had to tuck my tail between my legs and have somebody else finish.(2 new lowers) Be slow and hit them with as much penetrating oil as you can. PB Blaster is a great one.
MoparSickness77
MoparSickness77
I just kept using my 1/2 ratchet and twisting it around and soaking it with PB and the exposed parts that tapped it back in with the hammer and turned the bolt around to let the PB work inside the sleeve and bushing. It took time and then I just cleaned the bolts up good with my bench grinders wire wheel.
Orca
