charonblk07
- Mar 14, 2013
- 4,056
- 2,072
- Location
- Calgary, Ab
- 2009
- F1-A forged 349ci
what if i stick to the stand alone later and just stick to upgrading fuel pump now im sure it will be less expensive thelat stand alone sounds like a great idea but not something i want to try right now
If that's the route you want to go then I'd get the Aeromotive Stealth 255lpm pump, drop the fuel tank, and pull the basket. With the basket puled you need to remove the pump and filter assembly from the basket, you should be able to get the Stealth's pump outlet into the oem fuel line if not a small length of hose will work. Make sure you use a filter sock on the inlet of the pump. I tried to find some pics of my original setup but I got seriously screwed by photobucket.
