manupnorth
So I did the head gaskets on my non running ram I got. Not sure if it had power steering before I got it. Good part is now it's running great. No check engine lights but I have no power steering after I was done. With that a few questions.
Does it matter on the oil cooler attached to the radiator what rubber line was on what connection? Not the quick connects you use with a disconnect tool but the push on lines. I assume one is an in and ones an out, but would that effect it?
Secondly I ran the truck for a solid 4-6 minutes and saw no increase in temp on the truck and had no heat. But I'm kicking myself because I used the old thermostat. It was pretty clean so I assumed it was good. Yea I know. Rookie mistake on this one but I mention it just in case someone thinks if something I dont. I will do an Italian tuneup and love tap it tomorrow. Also, Yes I did replace the water pump and temp sensor under the air compressor.
If curious I replaced the camshaft, lifters, head gaskets, water pump, chromoly pushrods, temp sensor, had the heads resurfaced, new Mopar spark plugs and a new fuel rail (doesn't matter why lol). Think I got it all.
