No reverse lights
onlyonelikeme2015
5.9L magnum
I have a 99 dodge ram 2500, it use to have a lift gate on it. The guy that i bought it from took it off now i dont have reverse lights. Theres no wires cut new bulbs in it what could cause it. I've checked fuses and relays only thing i have noticed is in my fuse box inside theres a red wire that is just poked through and touching anything and goes back under the steering wheel into that wire harness.
mitchbowers
Ohio
1996 2500 5-speed, soon to be leveled on 33's
5.9 Magnum
Take a wire tester and see if you're getting power to those wires&yes check your fuses.
Sent from my A0001 using Tapatalk
casey1981
