Noise after 37's
moparmorris
Ever since I set my bils at 2.8 and went to 37's, I get a noise under the dash whenever I'm turning at speeds below 20mph. It sounds like either the abs or esc is kicking in. Does anyone have any ideas or have the same issue?
Thor09
Northern PA
I get the same noise once in a while, only when turning. I believe its the abs kicking in due to the larger tires.
bigtim1985
NJ
is your traction control light going on and off while you're turning? i had this problem until i got my truck aligned after i lifted it.
moparmorris
moparmorris
I was guessing the abs because the traction control light isn't coming on when I hear the noise
moparmorris
moparmorris
I live in Wooster, Ohio. Where are you at in Ohio?
moparmorris
moparmorris
I don't think I've ever been down to Coshocton. I've been to all the surrounding areas
gassersarentdead
ohio
Well and dale Jr and Martin truex was here last weekend. They bought land two properties over from ours. Apparently they hung out and had some beers in roscoe village. Guess they bought it for hunting.
moparmorris
moparmorris
Wow that's crazy
sausec17
Banned
ATLANTA
I have the same problem, removed the abs fuse and it still did it
