Noise when accelerating
sitdownicantsee
North Carolina
2017 5.7 2500...sounds like a belt but I’m not sure- I couldn’t find any “tabs” on the exhaust or anything touching it that would make the noise. It sounds like a rattle can bring shaked fast. You can hear it faintly at idle, it’s not the Hemi tick. It matches with engine speed and has a higher pitch when the truck shifts. Any help is great guys. Please ask questions so that I can better describe this problem, thanks fellas
MADDOG
Out Exploring Arizona
So it has a slightly metallic sound? Not a heavy metal clunk, right?
sitdownicantsee
sitdownicantsee
North Carolina
Yes a slightly metallic sound. It’s “rattling frequency” and sound level matches with how much throttle I give it. If you thumb the bristles on a comb real fast that’s about what it sounds like.
MADDOG
It sounds like it may be an exhaust heat shield.
ExpressRules
Southern New Jersey
2014 Express Crew Cab & 2019 Big Horn Crew Cab
If you had an older RAM I'd say you should check if coming form the cat convertor. When the interior element starts to deteriorate sounds like a "rattle can". However in your case, Just as MADDOG says, check heat shield and rest of exhaust connections.
Rampant
NJ
392 Hemi
If you hear it most when accelerating, it's probably not the same sound you're hearing at idle. What brand & octane gas are you using? It could be pre-ignition from poor quality or low octane fuel. Did this (start) occur (ing) shortly after a refuel?
sitdownicantsee
sitdownicantsee
North Carolina
I’ve tried putting a tank of 92 in it but it didn’t change anything. I’ve had it for a month and I noticed it the second day I had it unfortunately.
sitdownicantsee
sitdownicantsee
North Carolina
I can hear the noise when giving slight throttle to medium throttle, but I do not hear he noise when the truck is in Park while giving it throttle.
Rampant
NJ
392 Hemi
Is it completely stock? If not, a list of mods would be helpful. Any recent maintenance done to it? Try another tank of high octane gas and/or add some octane booster/fuel system cleaner w/strong dose of PEA such as Amsoil PI or Redline S1. If you bought it used, can you tell how many idle/driving hrs are on it in your evic? Many 3/4 tons are purchased as fleet vehicles and a good portion of them sit and idle for hours and hours, causing carbon to build up.
Jwithing
STL
Does the noise sound like "VRRRRRROOOOOOOOOOOM"?
Sorry... Ignore me... I couldn't resist
XXSNOTRODXX
MI
Did you ever figure it out?. My 2011 I noticed recently started having a similar issue. I haven’t looked it over real well just yet but I did crawl under and snap off the exhaust tab at the Y pipe that some say causes noises. Unfortunately that didn’t get rid of the issue. For me my engine is whisper quite (not even the typical hemi tick) except on cold start I have a little exhaust leak that I beleive to be a manifold gasket. Once it warms up it quotes down though. In park or neutral I can rev it and it doesn’t make a peep. But if I put it in drive, out my foot on the brake and goose the gas I hear a rattle type of noise. It doesn’t sound like internal mechanical noise though. It’s a hard one to explain. I’ve been working on cars for years and years and haven’t had a noise so tricky to pin point before lol. It also makes the noise if I’m cruising along at just about any speed and quickly smack the throttle. Or even at part throttle slowly driving up a steep incline. I did notice that I can easily turn my clutch fan by hand and was wondering if maybe what I am hearing is my fan trying to engage or maybe a tensioner pulley rattle or something. I’m going to inspect things further in the next few days and I’ll report back with what/if I find anything in mine
