O2 sensor
briant87
So I had a misfire on coil #5 code pop up and came along with low oil pressure code. I swapped the correct coil and the corresponding 2 plugs. The code went away but I got a P0058 code, HO2S Heater Ctrl Circ Hi Bank2 Sens2. I tried reseating the coilpack and replugging in connection, also tried disconnecting neg battery terminal, and clearing codes through scanner.
I have not checked or replaced O2 sensors yet just seems like too much of a coincidence that it showed up right then. Any ideas would be appreciated
Thanks
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I would do as you have done and reset everything and see what pops. High voltage on any sensor usually points at being unplugged. On a O2s it could be a burned out heater.
OasisNinjaBat
