OBDLink MX+ doesn’t detect “service air suspension” message?
DBryant
Maine
5.7L
Hi
I installed a brake control on my 2017 1500 Laramie Limited. Bought an OBD genie to flash the ecu. It worked but now shows “service air suspension“ message on start up.
the air suspension is working fine though.
I bought the OBDLink MX+ and did the updates.
it does not detect the error code or message…..
any thoughts?
D
DBryant
Maine
5.7L
Using the app on my iPad. It’s the latest software. Just received it 3 days ago on Amazon
Administrator
Chances are the OBDLink software can't read the air suspension codes, usually need more advanced OBD reader software which is usually licensed.
AlfaOBD should be able to read the codes and reset if needed. Unfortunately there is not Apple version of AlfaOBD, you would need to use a PC or Android
D
DBryant
Maine
5.7L
If I get a cheap Android tablet it will run the program, correct?
