I used these modules. And they have a backup camera input wire. I believe it's purplethe steering guide lines are controlled through the BCM. lots of cams come with the fixed guide lines.
what canbus module are you currently running with your pioneer? if any. some canbus modules can utilize the factory cameras. if this is the case you could do the OEM kit into the canbus module out to the pioneer.
IMO just buy any cam and use it. On my old '13 i just used a $30 amazon cam it had fixed grid lines so i just had to get use to what they meant.
Just like baum said which is the same thing I did and I have the same head unit as you
Sent from my Note 5 using Tapatalk
I would have to look at my other post but it's just like this one
http://www.amazon.com/gp/aw/d/B00B2...FMwebp_QL65&keywords=backup+camera+for+trucks
I got the Gino for my front and rear camera. Been 4 months for the rear and had no problems with it! I got the x5800bhs.
https://vimeo.com/158533468
For $10 it is so worth it and the video is surprisingly clear. Looks just like the one on my 2013 Mercedes. The lines are static though.
I wired the red to the reverse trigger on trailer wiring just the red from the camera not the RCA black obviously to ground, ran it up to the head unit and just plugged in the RCA to the Brown input on the back. So leave the reds alone on RCA leads
You can also splice the RCA red wire to the 12V (red wire) on the head unit harness. The red runs the whole length of the cable to the other end and wire that to the red camera harness. Then all you would need to do is find a suitable ground for the camera harness (I used the tail light ground since I didn't want to splice the hitch wires that is open to the elements).
I did that for both Gino cameras I have (front ground point was on the chassis). Also worked on the two different double DINs I have used. But each HU didn't like the same ground points for some reason.
The front camera is on the lower left grill. Can you find it?
Thx for the info guys. I'll rewire mine
I had to zoom in, but it's on the passenger side lower grill, about 2" up from the bottom?
