OEM LED CHMSL with Cargo Camera connected to 8.4RA
Deepc6
Long Island
Hemi 5.7 Etorque
I’ve posted the whole process of what needs to be done to make it work over at this thread. I’ve built several of these harnesses for people now, and use the i440 connector to get power, ground, and Lin. Depending on the trim of your truck you may just need to go to the green connector behind the headlight switch and not all the way to the radio connector.
https://www.ramforum.com/threads/installing-oem-backup-cam.53505/page-102#post-1404552
Hello DeereGuy,
I have a question regarding the install, I have a 2016 with 8.4 screen. Currently I have a PAC BCI-CH41 which acts as my navigation bypass with extra inputs from camera via a RCA input. I have access to a mopar 68163937af third brake light with camera. Is there a way to make a harness for this to make it work?
rgardjr
Hello DeereGuy,
Almost identical to the instructions that I provide earlier in this thread. You do not need to use the bus connection. Since you’re using an RCA connector and not pinning the harness you can just cut off a connector from an old RCA cable. You just need to get a camera wiring harness that has the connector for the camera on one end. I ended up with an extra one of these from my project.
15limited
Rain city
Cummins
Does anyone know where can I get the wiring harness for the cargo camera? I have 2015 3500 limited. And I just found an Oem cargo camera, and I got obdlink. Where can I get that wiring? I conctacted DeereGuy but he’s not replying.
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
Another option for @DeereGuy ....
fill out the contact form at www.kaodtech.com
Thanks,
Mike G.
PS: we both have regular full time jobs in addition to the harness work but try to get back to everyone as soon as possible.
M² Mods.
icetraxx
I never heard back either so I ended up making my own. I followed the instructions in this thread https://www.ramforum.com/threads/oe...amera-connected-to-8-4ra.125421/#post-1805236 Finished up the install this weekend. Had one hiccup. The diagrams I found showed the pinouts as from the front of the connector not the wiring side. I was 1 wire off on the harness to the radio. I only needed the power wire and ground for the connector in the drivers c pillar. The canbus wire might be needed for the alignment lines, but I didn't need them. I just wanted the view of the bed. Works great though.
15limited
Rain city
Cummins
If I don’t get a response, I will have to do this, thanks!
15limited
Rain city
Cummins
Got the wiring, installed it on my 2015 with 17.43.01 and enabled with it Alfaobd, it shows cargo camera button in controls, when I press it only shows backup camera and no option to switch to cargo. And also when going to reverse it doesn’t go to back up camera, unless I manual select the cargo camera than it will show back up camera. Anyway possible to downgrade to 17.11.01 version? Really need this to work
Mpgrimm2
Preferred Vendor
SC
5.7L
Message sent with info to switch the inputs to display correctly once you get the 17 radio installed to support both cameras.
M² Mods.
HemiLonestar
MD
I never even noticed that this was in the wrong section LMAO...this is 3rd gen
