chamolie
- Joined
- Jun 18, 2017
- Posts
- 73
- Reaction score
- 37
- Ram Year
- 2016 SLT
- Engine
- Cummins 6.7
This weekends project will be to install the OEM LED CHMSL with Cargo Camera to 8.4 RA4 screen.
AlfaOBD has been used to enabled "CHMSL Camera" in Car Configuration Change and the screen turns blue when the cargo camera is selected (Ready to receive and display signal).
I am going to build my own harness and install this weekend.
Pictures to follow...
List of items:
Mopar OEM LED CHMSL with Cargo Camera - part #68163937AJ
Mopar wiring tailgate - part #68189124AC (to connect to camera)
Cargo Camera wires:
will cut harness connector and strip down to the 6 wires only that connect to the camera
Red = Switched 12v power
Black = Ground
Green = Camera Signal
Clear/white = Camera Return
Yellow = Camera Shield
Blue = CAN bus
8.4 stereo Connector: 16-17 Radio Setup (& radios w/ v17.x SW)
(Sig / Sig Rtn / Shld)
Backup Cam: 31 / 32 / 33 (if not in Mirror)
CHMSL Cam: 24 / 25 / 26
Front Cam: 21 / 22 / 23 (VES - Req's custom SW or module)
Connections Required:
Red (switched 12v power)
Black (ground)
Green (camera signal) - connect to pin 24 at rear on stereo connector
Clear/White (camera return) - connect to pin 25 at rear on stereo connector
Yellow (camera shield) - connect to pin 26 at rear on stereo connector
Blue (can bus) not sure if required to be connected to can bus as there is no option to toggle lines ON/OFF will try without and update post later
List of items:
Cargo Camera wires:
Black = Ground
Blue = CAN bus
Black (ground)
