- Apr 28, 2012
- 23,283
- 45,022
- 2010 Hemi Reg Cab 4x4
- Hemi
I like it, honestly who cares what dave would say anyway. This is the winner imo.I'm going with, "Slick injectors"
Okay you posted the RL2 right when I was typing that.
I have no idea now
I like G's idea better,although this supposed to be a family friendly siteI'm thinking red line, lol?
Glad you opened this thread, cuz that was a question I always wondered about. So here's another question: how long before the oci should it be run...a week or two? Or longer?After running a full bottle of si-1 your oil smells like a chemical, now two uoas both showed an increase in viscosity, one small one larger by 2 points, so if you visc was 12 it could be 12.1 or up to 14. I do believe this will take more then one bottle, but the risk is noted. Plus, all the carbon it liquefies goes somewhere as well, right into your sump. I'm sure some ends through exhaust, but also oil. So it is a soft suggestion to change oil. However, because of how this works, it is some type of coincidence that the use of this product seams to be most effective in a larger dose then the maintenance dose, so it just seams to make sense to run this at the oil change interval instead of constantly.
What's the risk? Increasing viscosity?
Crud getting in the oil?
Kreen is some real good stuff, did you use it through the gas or sprayed into combustion chamber? I would think that product through chamber will also melt crude.Thinking about trying 3 bottles of SI-1 16 oz to 3 gallons of gas on this Civic that I think has coked oil rings if the Kano Kreen soak doesn't work. Borescope arriving today.
Going to do this weekend because it's my daily driver for work.........will pull spark plugs & keep tops of pistons covered with Kreen for 2 days.Kreen is some real good stuff, did you use it through the gas or sprayed into combustion chamber? I would think that product through chamber will also melt crude.
Well I take that back, just did an oil change so will do the next 2K since I have a quart of the HPL engine cleaner in the oil.
Wanted to do another oil/filter change after the soak.
Which product?Anybody know the chemical HPL is using? @Travis8352 ?
engine cleanerWhich product?
