If you had reason to remove your intake manifold, then use a borescope to see inside it, what would make anyone cuss, is what the valves look like, with all that carbon build up & what happens when some of that carbon breaks off
you would realize all the gunk & carbon that builds up, it would make any shadetree mechanic tear up.
We look at why you must fit an Oil Catch Can, or Crankcase Breather tank to your engine.Find out the Pros and cons of catch cans and catch tanks or separator...
www.youtube.com
If & when you buy a Catch Can, you will realize that it is a
Air/Water/Oil separator, just like you see in Paint Shops, it will be mounted fairly close to the Air Compressor.
It removes all or at least most of the liquids from the air line.
Then close to the Paint Sprayer,, you will see a short hose connected to the supply hose, that is called a Whip,
connected to the Whip is another Air/ Water separator, it is much smaller, that insures that only Air & Paint shoots out of the gun.
One other thing, some catch Cans have a base that you unscrew to empty the liquid, while others have a petcock in the base, those you can slip a hose on the petcock & open the valve, so you can put a container on the ground to catch the liquid.
I put this on my 2009 Dodge Ram HEMI
