Reece Tomlinson
I’ve got a 2002 Ram 1500 3.7l v6 and I discovered a pretty bad oil leak under the truck. Was coming from the oil pressure sensor where the plastic goes to the metal nut. I changed it, all ok. 3 days later the same has happened so put it down to a faulty part so replaced it again. The same has happened again. Pretty bad oil leak.
Any ideas to what’s causing this and how to fix it? Cheers
