Here is what I think the problem is with AGS.
I’ve been thinking about removing the active shutters. A couple concerns:
1-will it void the warranty??
2-do the temperatures stay more consistent? Mine swing by sometimes 25+ degrees and seems hot to me
3-I bought a kit to fool the computer to think they are still there but I’m second guessing the idea of removal.
This is only my opinion
1. Be on the safe side and assume it will void the warranty.
2. The temperatures will absolutely stay more consistent without the active grill shutters. 25° Is a big swing in temperature. Heat is what kills.
3. You can either install your kit or remove all of the shutters except the top and bottom ones. Whatever you do make sure you can return it to stock if any warranty issues arise.
I posted earlier in the thread documenting temperatures before and after removing all of the shutters except the top and bottom. It’s my understanding that the main reason for active grill shutters is aerodynamics and to help the engine warm up quicker. Hotter engines burn cleaner. Why are they there for aerodynamics? To get a gain of 0.1 mpg. Why are they there to help your engine warm up quicker? Because there is a race between car companies to get their vehicles to warm up the quickest, the quicker they can get your computer system operating in closed loop the sooner the engine will run at its “cleanest.” While your vehicle is warming up the computer is in open loop mode. This means all the emissions stuff is pre-determined and isn’t actually taking any data from the vehicles emission sensors. once your vehicle is warmed up it looks at all the emission sensors and fine tunes everything.
All this set aside there are two reasons I removed my shutters.
1. Large temperature fluctuations and high temperatures are not good for the motor, oil, transmission and trans oil.
2. Heat soak. Consider this, a truck without ags the engine coolant temperature is controlled only by the thermostat. If the engine coolant temperature rises above the thermostat setpoint the thermostat will partially open or fully open depending on the temperature. The “pre cooled” coolant moves from the radiator that is always been cooled by the air passing over it. The engine is receiving relatively cooler coolant whenever the thermostat opens. Now consider your truck that has Ags. Let’s say you’re driving down the highway. The engine coolant temperature is 210°. Your thermostat will be almost all the way open or completely open. But your AGS won’t open until it hits its preset temperature. Once the shutters open The coolant in the radiator and in the motor have to cooled down at the same time. If your truck doesn’t have shutters the coolant that is in the radiator will be much cooler “relatively“ and will cool your engine much more efficiently.
My advice do what you want….. and don’t spend too much time thinking about it. You will get a lot of difference answers from people who think they are right and everyone else is wrong.
