I tried this on my 15, I got the console in no problem, ran wires for homelink to what I think is the Linbus as well as power and ground. I took the truck to the dealership for the code to be added and the tech couldn’t get the programmer and homelink module to link? I checked out my install and found out the module failed so, I replaced it and the module worked for about a week before it failed as well. Not sure why the module, keeps failing but I just stopped trying on this one. Input power is 12vdc and the linbus seems around 3-8vdc if that’s the linbus on this truck? I’m not sure my year will work without the linbus either since without that wire connected the lights on the key pad don’t work, with it they do? Anyway, just giving you my experience doing this project. With a 14 I don’t think yours needs to go thru the linbus links mine but I could be wrong on that? Maybe Rocks Ram can give you a little more?
