P018C
JBow
Cookeville,tn
3.6 eco
2017 ram 1500 3.6 eco.
Have a P018C code: fuel pressure sensor circuit low.
Now, models before mine have a fuel pressure sensor they can order by that name. Mine does not. It’s called something else. When I called dodge, they told me it was built into a fuel line and I needed to get that for $300.00. When I asked for they part number, they basically hung up on me. They want to do the work themselves I suppose. Can anyone help me find the part number I need for this code? It’s a generic code so.
Tach_tech
5.7L HEMI
That code doesn’t mean it’s needs that sensor. It could also be the wiring or the PCM.
This is the part number though 68268051AA
J
JBow
Cookeville,tn
3.6 eco
Understood. I’m under 30k miles. I could swap the sensor fuel line myself. But if there is a decent chance it’s the other 2 options, I would actually save money at a mechanic since I can’t test the electronics. Tough decision. Thank you.
Tach_tech
5.7L HEMI
The most common failure I see with that code is the sensor, but you never know.
SRLMARK
Strawberry Plains Tn
3.6 v6
Do you have the part number for a 2017 3.6 flex fuel? Everywhere I look the part number you posted doesn't fit my truck and I've searched google for one and can't find one that says it fits. Thanks!
Tach_tech
5.7L HEMI
Looks like you need to buy the line to get the sensor.
68240036AA
JustinRam1500
