P0406, P0058, P0038, P0403 03 Ram Hemi
Austin Andersen
Kc
Converting my 03 to 05 pcm so I can tune it. I found out that originally the 05 pcm was never worked on to put my vin in which lead to diablo locking up. Im sending to b&g to get vin flashed, egr delete, and rear o2’s deleted. Im pretty sure thats some of the codes Im getting. Truck has been sitting cor years in garage. Put in new gas and changed oil/filter. My wideband probably needs callibrated so dont know if they are accurate. Just thought Id post the codes here to see if theres something else obvious that im missing.
https://imgur.com/gallery/FJ7fULq
https://imgur.com/gallery/QIb1P2U
[URL]https://imgur.com/gallery/iqGhu6g[/URL]
LoneWolf3574
P0038 P0058 - O2 sensor 1/2 and 2/2 heater circuit high
P0403 P0406 - EGR open circuit and EGR position
Easy enough to google on the interwebs. Since you're getting your PCM VIN flashed by somebody and removing the EGR and post cat O2 inputs, then I don't worry about those particular codes.
https://www.troublecodes.net/obd2/
A
Austin Andersen
Kc
Thanks. I googled the codes and that’s what it seem to be related to but I wanted to make sure it wasn’t missing something else that needs fixed.
