prs3603
Last night I was parked on my driveway and after putting the parking brake on, I went to go leave and pulled the lever. The pedal came back a little bit but the light was still on. After some investigation, I found that I had to pull the lever and also pull the pedal back further so that it turns off the light and I would assume completely releases the parking brake. Does anyone know what the issue is? Do I need to buy a new cable? Is the lever messed up or are the shoes shot? I have not been able to go underneath my truck yet as I have been working. Will do that later. Have seen some articles about having a loose cable that just needs to be tightened. Is that the likely cause? Or is the issue located at the pedal?
