"Parking light out" error with AlphaRex headlamps
antlmusi93
Pittsburgh
Hello all! Recently bought a 2015 Ram Big Horn.
I Installed Alpha Rex Nova Series LED Projector Headlamps with DRLs. The headlamps run and function properly, but every time I start the truck I get a "parking light out" error on my dash. Almost every time I turn on a turn signal while the low beams are on, the same error pops up and its driving me insane.
I purchased AlphaMod and the remaining fault codes are
B16BF & B16C3 which are front left and front right side marker lamp control short circuit to + battery/open circuit.
I turned on the following features in alphamod's carconfig but the error prevails and I really need some help.
"LED Front turn lamps present"
"LED Dedicated DRL Present"
"LED Low beams present"
"LED High beams present"
"LED Front park/marker lamps present"
Has anyone had this issue and resolved it in the past?
Thank you very much!
tzmndvl308
az
Contact Alpharex about this and they will send you a couple of resistors that will take care of the problem.
Orygun Bob
La Grande, OR
Diesel 6.7
Do these attach to both the left and right lights?
Also it looks like they attach to the turn signal bulbs is that correct?
