Pin connector removal tool
Wicklundwf
I have a bad wire that's too close to a multiwire connector. I have looked on eBay for a pin removal tool to better repair the wire. Which pin connector removal tool do I need?
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
If you're talking about the wire terminals, you're better off buying a set and matching it up to one from the set.
W
Wicklundwf
Ok so your saying to buy the correct connector and splice the dozen or so wires because of 1 bad wire? It's the large connector that's behind the driver's side fender by the frame.
dudeman2009
Magnum 360
No, there are kits that have wire terminals of various size and design, that way you can match up the one you have among a whole set instead of paying a premium on a single terminal to possibly get the wrong one.
Something like this:
https://www.amazon.com/dp/B01LBRWZVC?psc=1
I have one similar to this myself:
https://www.amazon.com/Delphi-Weath...rd_wg=CbxXw&psc=1&refRID=Z83HC00A8EYAR2F84TV6
You dont even need to replace the connector body, you can just pull the terminal out and re-terminate it, as for the removal tool, this is what I have:
https://www.amazon.com/OTC-4461-6-P...rd_wg=m5X08&psc=1&refRID=YH2XN686F3PMWBRR3505
W
Wicklundwf
Thanks for the clarification. Great info.
RJKNOW79
