Plenum Gasket: What is it, where is it and what should I do about it? *INFO*
Discussion in 'Engine & Performance' started by dodge dude94, Sep 20, 2013.
Sponsored By: Moe's Performance
  1. tommyboi87
    tommyboi87 Senior Member
    861
    205
    May 28, 2014
    houma louisiana
    Ram Year:
    1999
    Engine:
    5.2 Magnum
    Ok so the intake and installation kit got it. As for the mentioned supporting mods, I have a cai and an aftermarket tb. Also aftermarket single exhaust. Anything else you would recommend, merc? You seem to know more about this topic than I do lol.
    Sent from my SAMSUNG-SGH-I527 using Tapatalk
  2. Merc225hp
    Merc225hp Senior Member
    5,141
    3,117
    Jan 13, 2013
    NA
    Ram Year:
    truck
    Engine:
    gas
    Your biggest bang lies in a tuner, you have the death flash 99% guaranteed. A tuner will get rid of this and alter your TQ management (very little in these years), fuel trim, timing and more. Next would be a set of 1.7 rr's or better a nice cam.
    With this all said you should do a comp test on the motor before you get mod happy. Also a good A/F wideband gauge is nice to have and will help with getting your tune spot on.
    Edit; With your truck and motor = 390 stroker kit.
    dodge dude94 likes this.
  3. tommyboi87
    861
    205
    May 28, 2014
    houma louisiana
    Ram Year:
    1999
    Engine:
    5.2 Magnum
  4. tommyboi87
    861
    205
    May 28, 2014
    houma louisiana
    Ram Year:
    1999
    Engine:
    5.2 Magnum
    Kinda getting away from the original thread, sorry, but y'all got me curious lol
  5. 360Mag
    360Mag Junior Member
    Aug 1, 2016
    Ram Year:
    2001
    Engine:
    5.9gasaholic
    Helped my son replace plenum gask on his 01 5.9. Took most of the day but replaced cam sensor, rotor, and cap. Also valve cover gask.Just got this truck short time ago. Thanks to the forum we were able to diagnose and fix it. Not sure if cat is plugged but ecm has death flash sticker.Think o2 sense is good (no code). Got plenum kit from Hughes. If I had extra intake pan I would have made my own.It's just 1/4 in alum.I'm new here so forgive my rambling.
    dodge dude94 and Deepfried like this.
  6. pajeepman
    pajeepman Senior Member
    128
    Aug 30, 2015
    SE PA
    Ram Year:
    2003
    Engine:
    5.9 magnum
    So it sounds like if you reuse the stock plenum pan you should to shorten the bolts. It would make sense to me if you a thicker aluminum pan you do not need to shorten the pan bolts, correct?
    Sent from my SM-J320P using Tapatalk
  7. pajeepman
    128
    Aug 30, 2015
    SE PA
    Ram Year:
    2003
    Engine:
    5.9 magnum
    Anybody?
  8. dudeman2009
    dudeman2009 Senior Member
    22
    1,395
    157
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    2001 1500 Sport with enough electrical modifications to make my brain hurt
    Engine:
    Magnum 360
    As far as i'm aware, a thicker gasket or shortening of the bolts will suffice. I've heard of doing both.
  9. Truemagnum15
    Truemagnum15 Junior Member
    28
    Oct 26, 2016
    Washington State
    Ram Year:
    1999
    Engine:
    5.9L
    All symptoms listed are symptoms my husband has experienced through the past few years which has led him to plans of sending his engine in for remanufacture. He thought he had blown head gaskets and used Blue Devil a few years ago, which stopped the water consumption and noticeably slower the oil consumption. If his heads were cracked instead of blown gaskets, would the Blue Devil have helped this as well?
  10. dodge dude94
    dodge dude94 Senior Member
    23
    27,424
    6,268
    Sep 5, 2013
    East Texas
    Ram Year:
    1998 Ram 1500
    Engine:
    5.9 Magnum
    Technically it shouldn't have had an effect on oil consumption but I've seen weirder things.
Share This Page
