Post up your avg. Xsmn temps
R.L.K.
Bristol , Tn.
Hello all , I'd like to start a thread on posting up your avg transmission temperatures.
Please post what xsmn to have ie .. 6 speed or 8 speed and your year model and approximate milage .
Thanks ! I'll start
2014 Ram 1500 4x4 QC
65RFE 6 speed xsmn
49,000 miles
Winter = struggles to get to 125°
Summer = 130 -140°
Towing = highest I've seen was 155° while towing 7k lbs in 80° temp
Thanks !
Sent from my SM-G900V using Tapatalk
RysRam
Ontario, Canada
2013 Ram 1500 4x4 QC
65RFE 6 speed xsmn
44,000 miles
Winter = 170-180° after a decent drive.
Summer = 175 -180° after aux trans cooler install. Would typically be 175 - 188'ish before cooler install.
Towing = Would go over 200° when climbing minimal grades before cooler install. Highest I saw on my last trip after cooler install was approx 195° and it returned to 180° very quickly.
UnsatFC
Active duty NAVY
New Jersey
Is it just me or does that seem hot for a 6 speed?
65RFE 6 speed xsmn
44,000 miles
Hemi395
Cape Cod MA
2013 1500 CC 5.7 Hemi
65RFE
31,600 miles
Winter: struggles to get to 120°, sometimes less than 100° if its really cold
Summer: 130 -140° (A/C usage dependent)
Towing: Highest its ever got to was 160° while towing around 5000lbs in 80°+
R.L.K.
R.L.K.
Bristol , Tn.
Yep seems terribly high , he is the reason I started this thread .
His #s are exactly in line with the 8 speed .? ?
RysRam
Ontario, Canada
I bet my temps will match those posted once I remove the TBV.
Here's a picture of my shifter. Please note distinct lack of dial and clear presence of stick and knob. Not pictured....knob taking picture :)
R.L.K.
R.L.K.
Bristol , Tn.
I would think so , but I can't be 100 % sure , either way I'd be changing your fluid !
ScottFL
U.S. Navy Gulf War Vet
2016 RAM 1500 Laramie Longhorn 4X4
HEMI 5.7
2016 1500 5.7 8 speed 2800 miles
Only checked it a couple of times and it hovers in the mid 180's.
Next month I'm doing a 13 hour drive FL to Pittsburgh, I'll check it periodically and update the post.
02blkram47
Lebanon, NH
2018 Ram 1500 Limited
2011 Longhorn crew cab
65RFE 6 speed
Summer
76k miles
Sent from my XT1635-01 using Tapatalk
U&A
2016 3500 SRW
6.4 HEMI
2500, 6.4, 6 spd. Averages 170 towing or not, hot or cold..
Same but when towing 8,000lbs with ATF+4 and stock pan and a hot summer day i was reaching mid 180's.
But with Redline C+ and an PML deep pan. towing my
Temps have not broke 177 yet.
Edit: and i had stock tires with the ATF+4 and went up to 35" when towing with the redline C+ and deep pan. So there was even more working against it then. But my non-towing temps never changed.
huntergreen
RLK, IIRC. my 11 trans temp avg, between 160 to 185.
G-Ride990
Administrator
Administrator
Chandler, AZ
2016 4x4 8spd Hemi
Average is mid 170s. I've seen as high as 185 or so in our 100+ degree heat. Haven't had the truck long enough to see what it is in the winter.
A05GSHO
Southeast WI
65RFE 6 speed xsmn
32,000 miles
Winter = ???
Summer = 150, this morning on my way to work
Towing = ???
Booms
The OG
Ocala
2015 Express
Whipple 5.7 • SmoothBoost!
In the middle of a 12 mile ride to work. No serious
horseplay yet.... :naughty:
R.L.K.
R.L.K.
Bristol , Tn.
Thanks Booms !
8 speed xsmn I presume ?
Booms
The OG
Ocala
2015 Express
^ Yes.
dan1911
Fairbanks, Alaska
2013 1500 SLT QC 4x4
Dropped gf at airport (going on a polar bear tour in Kaktovic, AK while I "get" to go to work) and headed to work. About 25 minutes altogether with about 65-70% hwy
This is at idle while getting coffee but at speed was about the same except pressure was about 52
Sent via telepathy
