Power loss. Need help
Zazoos
02 Ram 1500 4.7 Automatic 4wd
Motor is freshly rebuilt (less than 250 miles). Throttle body cleaned. New IACV, Throttle Position Sensor and battery, ground clean.
Engine Codes are : P0031 Heater Control Circuit Low Sensor 1, P0037 Heater Control Circuit Low Sensor 2, and P0138 02 Sensor Circuit High Voltage
Power loss generally happens at slow speed. Only last about 10 seconds. No warning, no particular rhyme or reason on when it will happen. When it happens throttle response is almost non existent.
Otherwise motor runs smooth and crisp.
Thanks for the help.
Lowrider357
