power loss
linchpin
5.9 Magnum
when i first start my truck when its cold it runs great but after a while it just gets worse there is definently a noticable difference what could be causing that? just general wear and tear?
L
linchpin
5.9 Magnum
which brand would be the best?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
NTK is usually stock. Some trucks like Bosch, most like NTK.
WhiteExpress
Midland, TX
when i first start my truck when its cold it runs great but after a while it just gets worse there is definitely a notable difference what could be causing that? just general wear and tear?
Wear and Tear will not only effect a motor when it's warm.
It's very likely that DD is correct and you need a new pre-cat O2.
You can try unplugging it and driving around, this WILL trigger your CEL, but you can tell if that's the root cause. (when you do this, do NOT drive it hard)
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
I believe unplugging the pre-cat O2 tosses it into open loop mode....so it'll drink fuel but might run a tad better.
