Power steering fluid or ATF?
bIackjack95
Honolulu
4.7 V8
06 Ram 1500 4.7
Power steering cooler rusted out going to replace it I bought PSF from oreilly but reading more now and say to use ATF+4? Should I return it. I just bought the truck so I’m unsure if the previous owner used atf or psf? Is there a way to tell. I’m unsure what to do once I get the new piece on about the bleeding process.
Any help is appreciated
LoneWolf3574
Mopar (Ram trucks anyway) uses ATF+4 in its power steering.
tantore
texas
to bleed the P.s. pump turn the steering wheel left to right lock to lock 3t to 4 times to let the air out good luck
JimmyA
Northeast texas
With truck engine off, suck out reservoir replace with fresh fluid, start engine and do what tantore said! Should be good to go.
madtrucker2016
New York
I take my wife's turkey baster it works great and I empty it into a empty water bottle no mess. But I then have to buy her a new one to replace it
Orca
