olyelr
37’s on 20’s?
Congrats! Enjoy and take care of itFirst new truck I've ever bought. Couldn't be happier;-)
I’d sell them as spares and get AEV wheels. If you price them right they will sell. Even the bent one i bet. How bent is it?Haven't posted in a while. My 2018 is going strong. I recently bent one of my OEM rims somehow. Wondering if I should just replace it, or get new rims. Anyone else bent one?? I have been beating the hell out of it. It may have been a steep railroad track I impressively hopped over that got it.....
Where are you located? Are you breaking them up or as a set?I've got 4 to sell (with stock duratracs)
Perfect set up truck... looks great!
What running boards/nerf bars are those?
I’m in Southern California - I just posted them locally - was thinking it would be ideal to sell them togetherWhere are you located? Are you breaking them up or as a set?
Lund Latitude Nerf Bars.
Believe it or not I purchased them from EBay last year brand new for only $89.00 shipped to my door on close out. For that price how could you go wrong.
Yes I lost a little ground clearance With them but it made my wife happy getting into my truck.
Did you only level it to get the37's on?It’s finally nice enough outside that I was able to have a somewhat cleaner truck. Finally ordered another 37” spare. And no, it won’t fit in the factory spot. It’s in the bed.
The BFG's size up a bit smaller if I'm correct!?It’s finally nice enough outside that I was able to have a somewhat cleaner truck. Finally ordered another 37” spare. And no, it won’t fit in the factory spot. It’s in the bed.
It’s stock. Leveling won’t help with any rubbing without extra bumpstop. Only rubbing I have is at full turn on the sway bar to the right.Did you only level it to get the37's on?
Any rubbing when fully articulated?
No more than the rest of the tires. The majority of tire manufacturers do not measure what the sideway says. The only tire that’s even close would be the Goodyear MTR. The rest are usually 1.5-2.0” shorter than listed, mounted on the vehicle.The BFG's size up a bit smaller if I'm correct!?
No, not with factory wheels. You might have that problem with aftermarket wheels, depending on the offset. The only rubbing I have is on the drivers side sway bar, at full lock. Each tire and truck are just a bit different so it can vary depending on width. Like STT pros are about 1/4” wider and about 1/8” taller than my BFGs in a 37 so they might rub a bit more. Just examples.any trimming to fit the 37's?
