Problem Bilstein 5100 installation sway bar links
Mdezie
Hi new to the forum. I've done a lot of research on leveling my 2014 ram 1500 4x4 regular cab and chose to go the bilstein route paired with a set of 285 65 r20 BFG ko2's. im in the middle of my install and I've been following this detailed YouTube video https://m.youtube.com/watch?feature=youtu.be&v=GpLJIln6VBA
However when I went to reinstall my sway bar link it wasn't getting tight so I removed the nut to find that the threads were stripped. I thought maybe I over tightened it or something was bound up, so I drove across town to O Riley's and picked up a replacement and was very careful when installing it. I jacked the lower control arm got it lined up. This time worked the bottom bolt and top bolt a little at a time however when I went to do my final torque which from what I have found is supposed to be 27 ft lbs I never got there I stripped out my second link.... I'm frustrated and hope someone may have an idea or suggestion as to what I'm doing wrong before I try again in the morning.
Thanks, Matt
R.L.K.
Bristol , Tn.
Welcome to the forum sir !
Wish I could help more but 27 foot lbs seems high to me for the sway bar attachments, if I remember correctly you're just compressing rubber right ?
Post up a couple pics .
Have you done the other side ?
If not take a pic of it before you start , count the threads on the lower end , so you can reattach as it was before .
I didn't disconnect mine completly , I loosened them only enogh to allow me to push the lower control arm down enough to remove and reinstall the shock & coil assy .
bigolayne
Springfield, MA
Same here. I just loosened enough and then snugged up after. I think R.L.K is dead on
bravada94
WV
I just finished my install of bils too. one of my sway bar top nuts stripped too. seems weird to me too that it would do that.
ksredram
Same thing here. Replaced mine and just snugged them. Factories suck!
Ecodiesel
Mine stripped too in the exact same spot. I had hell on this install today. Had to drive 2.5 hours round trip to find the part on a Sunday. Overall, I spent 8 hours ******* on this today and only got one side done. Here's hoping I have time to get the other side done, get alignment and new tires mounted tomorrow before I have to go back to work on Tuesday.
R.L.K.
Bristol , Tn.
When you do the other side ( take a pic and count exposed threads ) , and just loosen enough to push the lower assy down enough to remove the oem shock & coil assy . You'll need to push down again to install the coil with the Bilstein shock , then just tighten it back as it was before you loosened it ( counting exposed threads )
Not much tq. Required here , I did mine this way aprox 5000 miles ago and have had no issues .
Hope this helps !
R.L.K.
Bristol , Tn.
This is the photo I took before I started .Notice the amount of threads above the nut on the anti-sway bar.
Look close , steering arm is kinda in the way , but you can tell I did not even loosen the bottom , and i just loosened the top while still maintaining good thread engagement.
This pic is after I completed the install @ + 2.8 " , you can see I just tighten the top nut to where it was prior to starting the install .
Hope this helps
Ecodiesel
Hope this helps !
I got'er done this morning. Passenger side went MUCH faster because I learned a lot of valuable lessons on the drivers side. Got the other side done in 2 hours and did manage to get new tires and alignment today's. Drives great.
R.L.K.
Bristol , Tn.
Fantastic! I love the way my bilsteins ride ! Much better than stock imo.
