Purge valve solenoid on and off tick
Marshalljud
I’ve done some research and I have a ticking noise that’s goes on and off intermittently that I noticed at idle. Read that the purge valve activates to release fumes and it’s most likely that. I thought it was noisy injectors at first but the fact it stops every so often then comes back leads me to believe otherwise. Does this sound likely?
M
Marshalljud
Never noticed mine clicking…I replaced mine a month or so ago.
I’m not positive it’s making the noise but I read it’s possible. Could maybe be on its ways out? Cheap part so it’s not a huge deal if it’s the problem. Just weird how I’ll be standing in front of the truck and it’ll be quiet then start making the click/tick. Same with it stopping the noise. I’ll have to dial it in and really see how long it stays on for and how long.
ThunderMug95
North Prince George, VA
Was your AC or defrost on when you were listening?
M
Marshalljud
Could be defrost! I keep my heat to the floor/defrost option most often. Excuse my ignorance but would that turn on the clutch and make that noise?
M
Marshalljud
If you have a good scanner or AlphaOBD you can actuate the purge valve with the KOEO and hear just how loud it is/isn't. Then you could do the same for the A/C clutch and listen to hear if that is what you're actually hearing.
Good advice sir! I’ll try and get to a buddies shop being I have a simple BlueDriver scanner.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Shut off your HVAC system using the controls in the cab,
then listen for the clicking
Purge valves are not that hard to pull
once out, try to blow through it, if you can blow through it, go buy a new one
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Yes. When in defrost, even though it's cold out, the AC compressor clutch is cycled to keep the refrigerant and oil circulated through the system year round.
M
Marshalljud
Thanks fellas! When I get a free chance I’ll check to verify.
M
Marshalljud
Sat outside the truck and waited for the tick to come and it is confirmed the purge valve. Held my finger on it and it pulses quite a bit which I’m sure may be normal but I don’t think the sound it makes is. Going to replace and see if it quiets down.
Randy Grant
Ellensburg, WA 98926
The AC compressor runs in defrost to send dry air to the windshield. Has nothing to do with cycling refrigerant and oil. Otherwise it would cycle all the time.
