- Joined
- Apr 28, 2012
- Posts
- 23,432
- Reaction score
- 45,459
- Ram Year
- 2010 Hemi Reg Cab 4x4
- Engine
- Hemi
So... getting thru all these posts on the 'Hemi tick' here, I'm trying to sort things out to see if the recommendations apply to my issue.
I have a 2016 BH 5.7, that has a 'tick' on startup... which lasts from 30-45 seconds, before going away. Is this how everyone's "tick" starts?!? I use Mobil 1 full synthetic 5w20 (as recommended), change it religiously every 7,500 miles and have never had any issues with that brand of oil. I've used it in 3 Volvos (before I bought this truck) and those went strong to 200K and 225K miles.
At 55K miles on the truck, my factory warranty is obviously expired... but we bought an extended warranty with it for this very reason. So, is this something I should have looked at immediately or safe to run for a while? Will it get worse over time? Will the manifold bolts just all of a sudden 'break' on a trip up to the cabin??? I hope not.
Please advise when time permits. I'm a relatively new owner, and just realizing how widespread this issue is. We live in the Midwest, and winters are cold... so not sure going to a 30x oil is a good idea for those months. Just my .02 there.
Thanks in advance for any/all suggestions.
Gregg
So prior to owning my Ram I used m1 exclusively as well, but my engine ticked on it and PP, and is whisper quiet on redline 5w20 and 5w30. That was my truck, but the forum's experience is that 5w30 redline kills more ticks then 5w20 redline. Redline isn't mineral oil, it is pao and poe base stocks, and the cold properties of pao are second to none. In the mid west you will have zero issues with running redline 5w30. If you start up tick never changes even after an oil change, it might be bolts and not lifters, if that is the case no oil will help and it wont hurt anything. As far as all of your other points, kinda up to you what oil you want to run, we just have figured out some collective info on it and we share it.
The one in the middle is redline 5w30, it pours as good as the 0 winter rated oils, that is simply as good as it gets. But it is even better because as 0 winter rated oils loose vii's they become thicker, but pao is a stable base oil and will remain good low temp properties as long as your oil is good. The second video the redline stays clearer even over other top oils. First sign an oil is failing in the cold, it goes cloudy. Your oil will die from lack of tbn long before pao base stocks break down. You see base oil chart below, pao is the second one, as you can see in it's natural state it has the best cold flow properties, and that is the main base oil of redline, you can't have a high % esters and you don't need a high % os esters to get the benefit. Been using the stuff in the ram since 2011, and I guess I'm stuck with it. Good luck, Burla
