- Jan 17, 2016
- 14,076
- 24,428
- 14 Sport
- 5.7
They're in parallel,so basically you have twice the filter flow capacity as a single filter set-up,which = less filter restriction. I'm just running the cheap Transdapt set-up ,but i did give it a port job,by rounding off every sharp edge i could get a die grinder to.Sharp corners aren't good for flow or oil shear. I'm also running -10 (5/8") fittings and hoses.Wow, very nice. What brand/model of single oil filter relocation is/was that? Another project to add to my list!! With the dual setup are the two filters in parallel or series? I'm not sure that I understand how the increase in PSI occurs. Do you have a theory and if yes, can you explain? Thanks VERY much.
John
Trans-Dapt Performance Products 1227 Trans-Dapt Performance Remote Oil Filter Relocation Kits | Summit Racing
Free Shipping - Trans-Dapt Performance Remote Oil Filter Relocation Kits with qualifying orders of $109. Shop Oil Filter Relocation Kits at Summit Racing.
www.summitracing.com
