John Schmidt
- Dec 20, 2020
- 76
- 154
- Location
- Snowbird - USA
- 2020
- 5.7L Hemi w/FLOWMASTER 50 SERIES DELTA FLOW
Hello all. On my 2020 Ram 1500 Bighorn w/5.7 I'm looking at the radiator fan motor. There are 3 wires going to the motor, 2 are like 10 gauge, red for positive, black for negative, and then there's like a 22 gauge, green wire, that you almost can't see unless you're looking for it. Does anyone know EXACTLY what this thin green wire is used for? Has anyone put a DVM on these 3 wires during fan operation. Maybe Pulse Width Modulation??
Further, I could NOT find a Radiator Fan RELAY in the truck - there is a radiator fan fuse, but no relay to be found. Nothing shown on inside cover of fuse/relay cover in engine compartment. I called TWO Ram dealers, talked with parts, and neither of the parts guys could come up with a part number and/or location for a radiator fan relay.
Has anyone done any exploration into the operation of the radiator fan?
Backstory - I'd like to be able to manually control the radiator fan, perhaps turn it on a bit earlier than what seems like the 226F default setting.
No, I don't want to spend $600+ for a tune/pcm swap, nor do I want to fake out the computer by putting a resistor in parallel with the ECT sensor.
Any ideas/thoughts or better yet schematics w/labels?
Thanks.
John
Thanks.
John
