Jeff CA
SQUARE WHEEL WELLS! GM has no style or design talent except in Corvette and Caddy.
YES!!! I forgot to mention that. Thank you. The GMC's wheel wells are coyote ugly!
To be fair the transfer case with 4 auto in thr higher trimmed 1500's is just an AWD transfer case with a low range.
I disagree I know u have had problems but mine turns 1:1 even at idle it's 4x4 not all wheel drive
You are one of the lucky few.
Not really....a few....
There are two types of transfer cases for the new GM Half tons. Manual transfer case with 2hi, 4hi and 4lo. And electronic transfer cases with 2hi, AUTO 4, 4hi, and 4lo. There is no AWD setting. AUTO 4 simply engages the front wheels when slippage is detected out back. Similarly to how the Ram's AUTO and the Fords AUTO settings work.
Now, in older GM vehicles, like the first Gen Silverado SS (2003??) and the previous Cadillac Escalade's, and Yukon and Sierra Denali had a full time all-wheel drive transfer case. They did not have selectable modes. The were always on all-wheel drive.
But now the new Denali's Sierra and Yukons have a the 4 mode electronic transfer cases. Where you can select from 2hi, AUTO 4, 4hi, and 4lo.
The new Escalade still has "available" All wheel drive. Although you can get it in 2wd.
This has nothing to do with what I said... I was referring to rams transfer case. By definition however when in the 4 auto setting it is considered AWD.
I agree when it's engaged it's 4x4AUTO setting any any of the trucks is not AWD. Its part time 4 wheel drive. the fronts don't engage until slippage is detected. This is how the Rams, GM's and Fords work.
Either way. I get what you were talking about.
AWD is different than 4x4. AWD has a diff between front and rear and 4x4 does not it's chain driven 1:1. Yes there is a clutch connection but it's still 1:1 so it is a 4x4. AWD is not allways 1:1
Unfortunately sometimes its nothing when you select all with the Auto xfer case.
