chrisr5310
Has anyone here upgraded the rubber steering wheel with cruise, gear selection and dash controls in a 4th gen 1500 Express to a leather wrapped steering wheel with all controls including audio and heat function? Also, the truck has the RA1 radio that will be upgraded too. The new steering wheel should be here in a couple of days. I know in order to use the heat function I obviously need the wheel and swap out the switch board below the radio, and probably the clock spring. I'm guessing the wire harness in the steering wheel needs to be changed too. Is there anything else needed to make this happen? When talking to the local dealer today they said since the Express did not have the optional heated steering wheel the main harness and fuse box also has to be changed. Does anyone have experience with this?
