trooper1954
- Dec 4, 2015
- 10
- 0
- 2008
- 5.7 Hemi
Hi,
Problem began when I changed a 20 amp fuse that had blown for the rear passenger power point.
After replacing it, I now have no brake lights/overhead brake light while truck is running, and when the truck is parked and the ignition turned off, the brake lights remain on as tho on a time delay for about 5 minutes. The brake lights do not work when I brake...they are constantly on.I'm tempted to think that while I was checking the fuses (I only checked the 20amp ones) I may have returned one to the wrong slot?? I checked that and it doesn't change anything.....I'm going to disconnect the battery for awhile and see if this makes a difference. I have already checked all fuses and bulbs, and disconnected the battery for 5 minutes...bulbs were all good, and I've also installed a new brake switch to no avail.
Any ideas or help would be appreciated
Thank you.
Thank you.
