Rear diff help!
Bushwood,Md
I'm in the process of rebuilding my rear. I removed the axles spider gears etc, and can't seem to pull the assembly out It comes out maybe an half inch and gets hung up on something any ideas?
Harley Harrold
USAF Ret. 36+ years service
Mississippi
5.7L HEMI
There is a adjuster on the left side of the pumpkin that puts tension on the bearing pushing the ring gear against the pinion gear. The adjuster has to be backed off to remove the ring gear carrier.
jwheeler
Washington
There is a tool that you stuck down the axle tubes to move the adjusters.
