Hi all,
I've been lurking here for a while and considering buying a new Ram 4x4 CC with the Hemi. Sorry if this is a bit long-winded, but I'm trying to figure out which gear ratio I want, and I'm wondering about its effect on the MDS system operation.
I test drove a CC short bed with the 3.21 in it, and I was underwhelmed by the performance - very lazy throttle response unless I really put my foot in it, and the trans needed to drop at least 2 gears at highway speed to get decent acceleration. This got me to thinking about the MDS system - I would think that with the 3.55 or 3.92, the shorter final drive ratio might allow the MDS to operate over a wider speed/incline range vs. 3.21, unless there is a hard RPM cutoff above which the engine will always run on 8 cylinders.
So, can some owners with each of the available gears chime in and let me know about how often, and under what conditions, you see the MDS operating? Is there a set maximum engine or vehicle speed above which it won't work?
Thanks in advance.
Thanks in advance.
