Rear running/reverse light issue
Twinky_Bomb
5.9 Cummins
2007 Ram 2500, 5.9, automatic, Laramie. First rear drivers side running light stopped working, turn signal and brake light still work though. Tried swapping bulb from other side and still same result. Swapped bulb and socket, still same result. Also as of the other night the reverse lights stopped working. Passenger side filament was burned out, so replaced bulb and passenger side now works. Replaced bulb on driver side, still doesn't work. If anyone's got any suggestions as to where to start that'd be great. I checked fuses I thought might be related, those were fine. Thanks for any help.
Orca
