Rear turn signals and brake lights
Bud404
I have a 2007 ram 1500 mega cab. Its a great truck but yesterday I encountered a problem where the rear turn signals and brake lights do not work.
I have checked the bulbs an dthey work fine.
I have not modified anything with the wiring backe there and I do not see anything wrong with it.
I did plug in my trailer and oddly the trailer lights work fine.
When I turn on the blinker to either side I get the fast blink indication usually meaning a bad bulb but I do not seem to have a bad bulb.
Anyone have any ideas - I'm a little confused as to what is happening
Thanks
Buddy
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Could be a filament out, where they light up but don't blink. Also did you check the front bulbs when doing the signal test? oh and welcome to the site
quietpeen
2021 TRX
Hellcat
did you check the brake lights and the reverse lights?
HemiBabe
DFW
Hope someone can get ya fixed up, welcome to RF
B
Bud404
Update
The backup lights work - the tail lights work - the front blinkers work
The trailer stop tail and turn lights work
The truck stop and rear turn lights do not work
I replaced the bulbs just in case....but no change
Thanks
Buddy
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Does the third brake light work like it's supposed to?
B
Bud404
Yes the third brake light works properly
BlackedOutHemi
DFW, Texas
2012 & 2012
Okay, let me see if I understand this. You have an '07, so it has the after burners with only two bulbs, one is reverse, the other is running/turn/brake lights. The reverse works. The running lights work. But the brake/turn does not work on either side?
And have you checked the owners manual to check the fuses?
B
Bud404
That is correct and yes I have checked the fuse. Thanks
B
Bud404
My owners manual shows park lamp fuses for both sides checked verified OK
Center stop lamp fuse verified OK
Three trailer fuses verified OK
I cannot locate anything that indicates it is a fuse for turn signal or brake lamps aside from those listed above
Thanks
Deviate
St. Augustine, FL
2005 4x2
Even though the turn signals and stop lights don't seem to work and the blinkers give you the fast flash, can you tell if the bulb is actually lighting really really dimly? Also, does it fast flash on you with just the turn signal or is it the brake and turn signal together that does it?
Mine has done that and indicated a lampout. But the bulbs and all fuses were good. What I tried was completely removing the lights and the piece that bulbs plugged into and swapping them from left to right. Just to see what happened. They then worked. Switched them back and they still work.
My assumption in my case is that I have a loose connection there somewhere. :mad:
Bluesmoke91
2nd GEN Site Mod
Baldwin Park, California
Do your lights have accessible circuit boards like the 02-06 tailights...try swapping those...i swapped my left circuit board when I had a similar problem and it was fixed.
Sent from my DROIDX using Tapatalk
B
Bud404
Update
This does have plug in connectors at the bulbs.
I tried taking them off and testing for power with a meter and a light probe
no power getting to the blinker/stop filament. Tail light shows 12V no problem and of course it works.
I have a bad feeling the TIPM is shot. Not sure if there is a way to test that but I have run the wires back to the back of the cab and I have no voltage from the turn/stop circuits. I now understand why the trailer lights work - they have their own circuit - not just wired off the truck lights.
Any ideas?
I sure appreciate all the help ! Thanks Very Much!
smykowski
Pacific, MO
2010 SLT
6.7L Cummins
do these trucks even have blinkers on the fuse panel any more like the old cars do or is it electronically controlled?
quietpeen
2021 TRX
Hellcat
this is what I was just thinking. On the 02-06 the circuit boards back there are none for going bad. I had them go bad on my 05.
sketcher107
2077 Dodge Ram
Cummins 5.9
Sounds like you need your TIPM reflashed or replaced, I had the same issue
sketcher107
2077 Dodge Ram
Cummins 5.9
totally integrated power module
sketcher107
2077 Dodge Ram
Cummins 5.9
mine went bad and did the same thing try having it reflashed before replaced, $40 vs $900
Ludwing85
2007 dodge ram
4.6 v8
Hey i have same issue with my truck did you find the solution
JustinRam1500
