RearSliding window Question
holtff1074
Bristol Va
I just gotta ask this question although it's probably not any issue with my back window....or maybe there is. What catches my attention whenever I open my rear window I keep watch as it opens and notice once it gets within bout 4" of being fully open it slows dramatically.That may be normal,that I don't know so I thought I'd get feedback from others. I've even studied maybe feeding a little lube down to the track once it's open just as a preventive for any moisture that works in the opennings if caught in the rain...or maybe ....if left open at nite....just to see it rained the nite before. Curious what you guys think.
Sckotg73
Denver, CO
6.7L Cummins Turbo Diesel I6
same issue, might have them look at it next time I'm at the stealership and while its still under warranty
Jrod
USAF 1997-2008
Virginia
2016 Sport
Mine doesn’t slow down.
huntergreen
Mine doesn't slow down.
TerraNewf
NL, Canada
Mine is fine, same speed closing and opening.
Navy Six Zero
DFW
Sounds like debris in the track or the seal is pinched in a little bit during assembly, no issues on my 16
HEMIsphere05
MO
6.7L cummins
2016, mine doesnt slow down either. It's a constant speed opening and closing
jasonw
South Dakota
5.7L Hemi V8
Doesn't slow down on my 2014 either. As others said, start with the basics... does the track look like its slightly pinched at the end? Does it look a little dirty? Try some lubricant spray designed for weather stripping, see if that helps. My passenger side window chattered going down half the time until I used that stuff. Cleared it right up.
JB1
Houston, Texas
That's a good idea, do you have a link or remember what you used?
Sweep49
SWGA
Mine does slow down. 2018 Laramie new in October.
17crewram
North East Iowa
Mine did the same thing In my '17. I sprayed some PB blaster dry lube spray. Worked great
Sent from my SM-G930R4 using Tapatalk
Coramie
Lago Vista, Tx
Mine slows down about 4 inches out too. I’ll be looking into the lube soon.
bradw177
Pa
2015 mine slows, almost stops. But closes. And track is clean
